das2017
Jul 06, 2017Aspirant
GS752TXS Vlan setup
Hello, I have four GS752TXS switches stacked using the SFP ports 51 and 52 on each switch. Everything works fine. Now, I'm trying to set up at least two VLANs and are wondering what's the best ...
das2017
Jul 10, 2017Aspirant
Retired_Member, JohnC_V
Ok, so I set up VLANs on my router, but for some reason I'm getting an a VLAN1 IP address on my test machine instead of a VLAN10 IP address.
For the switches, I have the following configuration:
VLAN1:
- All ports are untagged ('U') except for port #38 on switch #3; it's blank--neither tagged nor untagged. (This is the port I'm testing with.)
- Router IP range is set to: 192.168.1.1-254
VLAN10:
- All ports are blank except for port #38 on switch #3, which is marked untagged ('U'), and port #2 on switch #4, which is marked as tagged ('T'). Again, that's the port the router is plugged in to.
- Router IP range is set to: 192.168.10.1-254
PVID is "1" for all ports except 3/38, which is "10".
When I hook up a laptop to the test port (#38), it gets an IP from the VLAN1 range.
Before I do some troubleshooting with the router, I just want to be sure that the configuration is correct on the switches.
Thanks again,
Retired_Member
Jul 10, 2017Hi das2017,
For further analysis, Could you please provide the config file of the Switch:
How do I send config files from my Smart Switch to NETGEAR community moderators?
- das2017Jul 11, 2017Aspirant
Hi Retired_Member,
I've sent the config file to the email listed at the bottom of the page in the link you posted.
Thank you,
- JohnC_VJul 11, 2017NETGEAR Employee Retired
The setup that you have right now is correct. You already Tagged the port going to your router and the test port 38 is set to U - VLAN 10, PVID 10. This should work on this setup unless the VLANs that you created on the router are still not set to Tag.
- das2017Jul 12, 2017Aspirant
Well, I figured out why the laptop was getting an IP address from VLAN1: it's because unbeknownst to me, the laptop was set up to recieve a static IP address. That issue is now fixed and the laptop is getting a correct IP address from VLAN10. However, I'm unable to access the Internet from VLAN10.
Any idea why?
Thank you,
- Retired_MemberJul 12, 2017
Yes, please check on your laptop, make sure the PC can get correct Gateway and DNS for DHCP Server. Otherwise, it will cause host cannot access to Internet.
- das2017Jul 13, 2017Aspirant
Retired_Member,
The laptop is getting the correct DHCP address, gateway, and DNS server information, but is still unable to access the Internet. At this point, I think the issue lies with router, so I'll continue troubleshooting that.
Thank you both, Retired_Member and JohnC_V, for taking the time to assist me with switch configuration.
- JohnC_VJul 13, 2017NETGEAR Employee Retired
That would be great! But I'm pretty sure that it would be coming already from your router. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
