masterkik
Aug 20, 2022Aspirant
GS908 smart switch firmware Update
Not clear how to get to Web gui fir smart switch GS908 as ip address mentioned doesn't open page, also does one have to use ethernet cable in switch to update. Also used discovery on WiFi and ethernet...
masterkik
Aug 28, 2022Aspirant
Don't have CD, plus not sure of how to get to Web gui as connected via cable first but ip mentioned doesn't work plus checked underneath device which still didn't resolve issue
michaelkenward
Aug 28, 2022Guru - Experienced User
masterkik wrote:
Don't have CD
That is where the support pages come in. Anything that was on a CD is there.
The GS908 is an Unmanaged Switch. What tells you that it has any firmware to update? The installation guide says nothing about that.
Do you mean GS908E? That's not the same thing.
Did you follow the suggestions in my previous reply?
Re: GS908 smart switch firmware Update - NETGEAR Communities
