gislovbrian
Jan 12, 2023Tutor
GS908E - where is firmaware file ??
Hi, Just bought a GS908E managed switch to add to my network . Checked if there was a firmaware update - there was - but no bin file only instructions. Have I missed something ? Brian
- Jan 12, 2023
Thanks for the help, I found out what I did wrong - updated now.
Brian
gislovbrian
Jan 12, 2023Tutor
Brian
Jan 12, 2023Guru - Experienced User
Glad to hear it!
You might mark it solved so others aren't still trying to fix it 🙂
- gislovbrianJan 13, 2023Tutor
It is these simple things - how do I mark it - solved ?
Brian
- plemansJan 13, 2023Guru - Experienced User
click "accept as solution" for the solution
