antzac67
May 11, 2021Aspirant
GSS108E Switch is not supporting 4K media streaming
I'm new on this community and this is my first post. I have two GSS108E Netgear Switches at home, one is dedicated to data and the second one is for TV boxes that now come with ethernet port and not ...
antzac67
May 12, 2021Aspirant
Thanks for your post, I have checked the settings you mentioned and they are and has been as you suggested. So it seems the problem should be something else.
Antonio
schumaku
May 13, 2021Guru - Experienced User
It might be required to update the unknown firmware on the GSS108E switches to enhance the ICMP Multicast handling - trouble is that Netgear has revoked firmware and some mandatory bootloader updates from the support downloads. YeZ please.
- antzac67May 30, 2021Aspirant
schumaku wrote:It might be required to update the unknown firmware on the GSS108E switches to enhance the ICMP Multicast handling - trouble is that Netgear has revoked firmware and some mandatory bootloader updates from the support downloads. YeZ please.
Thanks for your response, so if I understand correctly, there is not really a solution to my problem until Netgear offer a new firmware for my device? Is Netgear planning to release a new firmware for it? I've seen that the there is an FW version V1.6.0.5 for the GSS116E, but the newest for GSS108E is V1.6.0.4. Sould I wait for the new FW release or start saving for a new switch? - antzac67Oct 17, 2021Aspirant
I have found that there is a new firmware version for this switch 1.6.0.9, I have installed it and I was very hopeful my problem about the pixelated image was going to disappear but it did not. Any suggestions here, thanks in advance!
