MacNet26
Jun 25, 2018Aspirant
GUI of GS108Ev3 not available after firmware upgrade
Hi,
After Upgrading the firmware of my GS108Ev3 to version 2.06.03, the admin GUI of the switch is no longer available. In fact the upgrade process seemed to be corrupted. It said "transferring...
- Jun 26, 2018
Amazon kindly sent me a replacement device by now following their warranty policy. Thanks for your advice in trying to fix the switch.
Mac
DaneA
Jun 25, 2018NETGEAR Employee Retired
Hi MacNet26,
Welcome to the community! :)
Kindly try the following steps below:
a. Clear the cache of the browser you are using then try to access the web-GUI of the GS108Ev3.
b. Use other browsers like Firefox of Safari then try to access the web-GUI of the GS108Ev3.
c. Use other PC or laptop to further isolate the problem.
d. Disconnect the GS108Ev3 switch from your existing network. Connect a PC directly to a LAN port of the GS108Ev3. Then try to access the web-GUI of the GS108Ev3.
e. Install the ProSAFE Plus Configuration Utility on your PC then observe if the GS108Ev3 will be detected. Check the IP address of the GS108Ev3 that will be detected. Also, check what is the current firmware version of the GS108Ev3 detected by the utility. You can download the latest version of the ProSAFE Plus Configuration Utility here.
Let us know the result.
DaneA
NETGEAR Community Team
MacNet26
Hi,
A to D do not make a difference - as stated before.
E: ProSAFE Plus does not find any switch in the network, not pure locally (direct connection between PC or different laptop and switch, static or dynamic IP) and not via the router (also static or dynamic IP).
Mac
- DaneAJun 26, 2018NETGEAR Employee Retired
Thanks for the feedback. Since its still the same problem, I suggest you to open a chat or online support ticket with NETGEAR Support at anytime for further assistance. Indicate the troubleshooting steps you have done to isolate the problem. If ever the GS108Ev3 switch has been declared faulty, be ready to submit a .doc or .pdf copy of the Proof of Purchase or Sales Invoice of the GS108Ev3 for warranty verification. If ever the hardware warranty is valid, an online replacement will follow.
DaneA
- MacNet26Jun 26, 2018Aspirant
Mac
