Mic-cosmos
May 24, 2021Follower
Hash Mode and Throughput Problems With GS724Tv4 Link Aggregation (LAG) Using LACP With Synology
This is an updated set of questions to a problem that I had with a similar scenario here. Basically, with the previous scenario, I was able to "fix" the issue by setting the hash policy to "layer3+4"...
schumaku
Jun 21, 2021Guru - Experienced User
Mic-cosmos wrote:Default hash policy "layer2 0" on the Synology would only result in 1Gbps bandwidth while pulling with two clients. This is again "fixed" by changing the hash policy to "layer3+4".
Permitting this is tested on the same local switch: Reads to me the Syno does not properly put the L2 MAC TX hash policy in place. Nothing the switch can change on this....
Just for the curiosity, can you grab the Linux bonding driver details from the running system? Somethig like # cat /proc/net/bonding/bond*
