LouBen3010
Apr 01, 2019Aspirant
Heavy CRC issues in the network
Hi there,
in my network I use a DrayTek Vigor 130 and a Ubiquiti UniFi Security Gateway to connect to the internet. My ISP is Deutsche Telekom (German Telekom). After the Security Gateway a JGS...
- Apr 01, 2019
Assuming the cabling is good, no potentially unsupported (by some peers) Jumbo Frames active, the switch might be on the way out.
Give a try to factory reset.
Re-flash the current firmware - JGS524PE / JGS524Ev2 Firmware Version 2.6.0.24 (that's a version number - 1 April is just fools day, useless information for the future reader).
Give a try to factory reset, and re-configure.
schumaku
Apr 01, 2019Guru - Experienced User
- LouBen3010Apr 09, 2019AspirantIndeed it was broken. Just bought „real“ enterprise hardware and it worked out of the box.
