LouBen3010's avatar
LouBen3010
Heavy CRC issues in the network
Hi there,   in my network I use a DrayTek Vigor 130 and a Ubiquiti UniFi Security Gateway to connect to the internet. My ISP is Deutsche Telekom (German Telekom). After the Security Gateway a JGS...
  • schumaku's avatar
    Apr 01, 2019
    Assuming the cabling is good, no potentially unsupported (by some peers) Jumbo Frames active, the switch might be on the way out.
    Give a try to factory reset.
    Re-flash the current firmware - JGS524PE / JGS524Ev2 Firmware Version 2.6.0.24 (that's a version number - 1 April is just fools day, useless information for the future reader).
    Give a try to factory reset, and re-configure.
ProSupport for Business
