koa132435
Jul 16, 2022Star
HELP GS110EMX low Upload Speed when connecting at 2.5Gbps on ports 9 and 10
Hi All, I hope someone can help and point me in the right direction even though I think this is a software/hardware bug (I hope I am wrong). First - every time I connect on port 9 or 10 and c...
ubiquity42
Dec 08, 2022Aspirant
I have the EXACT same issue. 2.5g and 10g ports give extremely slow upload speeds to an ASUS AXE11000. 1g ports are fine. Link aggregated ports are fine.
This problem has been maddening.
- koa132435Dec 08, 2022Star
After long hours, actually days, and multiple tests and HW I found the solution: I replaced all my switches where I had devices connected at different speeds including the GS110EMX
I have successfully tested the following communication patterns:
2.5Gbps <---> 1Gbps
2.5Gbps <---> 10 Gbps
1.0 Gbps <---> 10 Gbps
In my personal conclusion, the problem sits with the switches and how switches handle the flow control and buffer the packets between devices connected a different speeds.
I will send you a direct/private message with the switch that solved all my problems. YMMV
