WouterB
Sep 26, 2016Aspirant
Help with basic VLAN setup for GS748Tv5 required
Hello, I am attempting to set up two ports on my GS746Tv5 switch to be a member of VLAN ID 100 (and only 100). The goal is for the two computers connected to those ports to be able to see each ot...
- Sep 29, 2016
Well, it works now.
I've power cycled the switch. Here's what I did:
- Created a new VLAN with ID 100
- Made two ports Untagged members of this VLAN 100
- Set the PVID of these two ports to 100
- Removed the two ports from membership of VLAN 1
- Connected two servers with IP addresses in the same subnet, no further configuration on the servers
Both servers can ping eachother. Computer attached to different ports cannot ping them.
Thanks for your help John,
Wouter
JohnRo
Sep 28, 2016NETGEAR Employee Retired
Hi WouterB,
I can't say it's a configuration problem as well. You did it right, removed them from VLAN1, untagged 10 VLAN 100, set static IP and gateway address and subnet. I believe it is best to contact our support team and have them take a better look at what you did.
Thanks,
WouterB
Sep 29, 2016Aspirant
Thanks John,
I'll try again, but this time with CentOS servers instead of clients and see if that makes a difference. If it doesn't I'll contact support.
Cheers,
Wouter
