DJDJDJDJ
Jul 22, 2020Aspirant
How do I configure VLAN with Netgear GS308E and Edge RouterX
Hello, I am trying to figure out how to configure VLANs on Netgear GS308E to work with Ubiquity Edge Router X. My current setup (as in the diagram) has two access points. AP1 is connected directl...
- Jul 22, 2020
For complex 802.1q VLANs configs use VLAN -> 802.1Q -> Advanced only.
Add VLAN 10, 20, and 30 to the VLAN config.
For the uplink port and the AP port, add VLAN 10, 20, and 30 as [T]agged.
DJDJDJDJ
schumaku wrote:There is an untagged VLAN ID 1, so PVID must be set to 1, too - otherwise your primary network (also the management network of the other vendor devices) will no longer work.
Hi schumaku,
Thanks for coming back quickly. I have done the config but for some reason, I am still not getting IP address for VLAN 10 (that's the only one I am testing right now). I have attached screenshots of the config. I can still get IP address for VLAN 1. Any ideas?
Thank you.
schumaku
Jul 23, 2020Guru - Experienced User
LAN 10, 20, and 30 are configured for tagged usage on port 7 (AP?) and 8 (router).
Your job to figure out on how this must be configured on the Ubiquity devices. They are hiding the thech facts - not Negear.
