Bizquick2k
Aug 29, 2017Aspirant
HOw do I setup a trunk port on this S330-28x?
I'm trying to connect this switch up to my main network. I mostly going to use it just as a Management device switch. Cause I never get into the temp controllers enough to waste ports of the server ...
- Aug 29, 2017
Hmmm,
I thought those smart switches had that menu.
Anyhow, you can just Tag the VLANs manually. Same thing.
See here.
https://kb.netgear.com/11673/How-do-I-setup-a-VLAN-trunk-link-between-two-NETGEAR-switches
Hopchen
Aug 29, 2017Prodigy
Hey,
You can set a port to trunk mode under: "Switching" --> "VLAN" --> "VLAN Trunking Configuration"
Cheers
Bizquick2k
I dont see that on my menus.
- HopchenAug 29, 2017Prodigy
Hmmm,
See here.
