Bizquick2k
Aug 29, 2017Aspirant
HOw do I setup a trunk port on this S330-28x?
I'm trying to connect this switch up to my main network. I mostly going to use it just as a Management device switch. Cause I never get into the temp controllers enough to waste ports of the server ...
- Aug 29, 2017
Hmmm,
I thought those smart switches had that menu.
Anyhow, you can just Tag the VLANs manually. Same thing.
See here.
https://kb.netgear.com/11673/How-do-I-setup-a-VLAN-trunk-link-between-two-NETGEAR-switches
Bizquick2k
Aug 30, 2017Aspirant
Well nothing is working.
I'm trying to connect this switch to one of our core switches. and nothing I can do seams to make this a trunk port that can access all the vlans.
I guess this switch can't create trunk ports.
I guess I'll have to junk this switch. maybe I can send it back. what a waste of 950.00 bux
S3300-28x 10g
