Bizquick2k
Aug 29, 2017Aspirant
HOw do I setup a trunk port on this S330-28x?
I'm trying to connect this switch up to my main network. I mostly going to use it just as a Management device switch. Cause I never get into the temp controllers enough to waste ports of the server ...
- Aug 29, 2017
Hmmm,
I thought those smart switches had that menu.
Anyhow, you can just Tag the VLANs manually. Same thing.
See here.
https://kb.netgear.com/11673/How-do-I-setup-a-VLAN-trunk-link-between-two-NETGEAR-switches
Bizquick2k
Aug 30, 2017Aspirant
Well nothing is working.
I'm trying to connect this switch to one of our core switches. and nothing I can do seams to make this a trunk port that can access all the vlans.
I guess this switch can't create trunk ports.
I guess I'll have to junk this switch. maybe I can send it back. what a waste of 950.00 bux
S3300-28x 10g
Hopchen
Aug 30, 2017Prodigy
Hey,
I can understand that you are frustrated, but this switch is perfectly capable of doing VLANs. It is a very capable switch, not bad at all - certainly not "junk" anyway.
It can do access ports and trunk ports with out any issue. Netgear allows you do that two ways normally.
1. Via the "VLAN Trunking Configuration" which falls more in line with traditional ways of configuring (access port mode and trunk port mode).
2. Do the VLAN trunking and access ports manually. Tag/Untag VLANs manually on ports and set PVIDs manually.
I can understand that you don't have option 1 available to you. That is fine. Both option 1 and 2 accomplishes the same thing. Option 1 is likely only available on fully managed switches.
Why don't you tell us a little bit about your config? This way we can perhaps help get it working.
- You are trying to trunk to a core switch.
- What VLANs run on that core switch? In other words what VLANs do you need to trunk between the S3300 and the core switch?
- What config have you done already on the Netgear S3300? Did you create the relevant VLANs? The port that connect to the core, exactly what VLAN config have you done on that port?
- The ports where clients connect to (access ports) did you remember to Untag "U" those ports and set correct PVID?
- The core switch you have. What brand is that? What config did you use on the port that connects to the Netgear S3300?
- Bizquick2kAug 30, 2017Aspirant
Okay I got it working. I figured out what I was doing wrong.
It took alittle bit to figure this out.
But its like netgear's term of trunking is a little diffrent than I expected.
this link helped once I understood what to do.
The biggest issue I finaly figured out was the other ports in the other vlans needed to be set as a U for untagged.
but the uplink port is set for T=trunking.
But when I create LAG ports it uses that term trunking in the port setup.
So again its just the way Netgear uses the terms is a little bit diffrent from other vendors.
But I got it working now so its good. Looking forward to see about connected my Synology box and see if the preformace will hold up.
- HopchenAug 30, 2017Prodigy
Glad you got it sorted.
Give a shout if you get stuck. Cheers!
