dwaynek
May 02, 2021Aspirant
how do i setup static lag on XS708e and intel x540-T2?
i can't seem to setup static lag on the xs708e. when i turn on admin mode, it locks me out of the switch and i have to reset it back to factory defaults in order to get back in.
also, how do i configure the intel x540 for static lag?
dwaynek wrote:i can't seem to setup static lag on the xs708e. when i turn on admin mode, it locks me out of the switch and i have to reset it back to factory defaults in order to get back in.
Use a different connection (port) to avoid cutting you off the switch connectivity for whtever resone.
dwaynek wrote:also, how do i configure the intel x540 for static lag?
This depends on the operating system of course.
- dwaynekAspirant
connected via a different port and it stayed connected. tx.
also figured out how to configure the x540.
