Dennis-L
Dec 09, 2020Follower
How do I update the bootloader to version V1.6.0.2-VB
Where can i find the update to update the bootloader to version V1.6.0.2-VB?
schumaku
Dec 09, 2020Guru - Experienced User
Can't see the screenshot yet - does the Web UI access challenge to upload the bootloader? Check earlier firmware builds - use "View previous versions" under the current firmware. However, the last one I can locate is GS105Ev2_loader_V1.4.0.5-VB.bin which came with v1.5.0.4.
Somehow I think we had this question before - you have to different GS105Ev2 switches, where the newer came with V1.6.0.2-VB?
Could be a manufacturing or minor hardware change requiring a newer bootloader.
Probably somebody from Netgear can answer and give some insight on the difference or the lack of availability of the V1.6.0.2-VB bootloader for download.
Edit: Same on the GS105PE - later manufactured devices come with V1.6.0.2-VB:
| Bootloader Version | V1.6.0.2-VB |
| Firmware Version | V1.6.0.6 |
The last available bootloader is on this older device, v1.5.0.5-VB became available some firmware releases ago:
| Bootloader Version | V1.4.0.5-VB |
YeZ can you challenge the switch engineering please? This could explain the oddities we see on the GS105PE under some conditions.
- YeZDec 09, 2020NETGEAR Expert
The bootloader version difference should not cause firmware behavior difference. Will check with the engineers.
