MotivIT
Jul 31, 2017Aspirant
How stacking works is 2 stacked switches?
Hi Experts, I'm new to stacking and I would like to know how it will work with 2 switches. I know that when these 2 switches were stacked, they basically become a single switch. Now my question ...
- Aug 05, 2017
Hi,
If device A is connected to switch A, and switch A dies - well then device A will loose access to the network.
If device A is connected to switch A, and cable between them fails then device A will loose access to the network.There is nothing you can do to prevent this and that is OK because high availability is not about end devices. It is about creating a resilient network to allow important devices to have high availability. Devices such as: servers, storage devices, switches, routers, etc.
A common way to create this high availability is through a combination of stacking and LAG (bonding). For example: I have a stack of two switches. I connect a server to the stack. The connection a done via a LAG of two cables, so that:
- One cable is going from the server to switch 1 in the stack.
- The other cable is going from the server to switch 2 in the stack.This is called making a LAG across the stack. This is possible to do as the switches in the stack are acting as one unit (like you mentioned yourself). Now, your server has high availability. If switch 1 in the stack dies, the server will still have connection to the network via switch 2. Same scenario if one of the cables fail. This high availability becomes even higher if you stack, say 4 switches, and then then make a 4 cable LAG (across the stack) to your server.
Now, all of this requires two things:
1. The device that connects to the stack is capable of configuring LAGs.
2. That the device connecting to the stack has several NICs.End devices only has one entry point to the network. If that entry point fails (cable failure or switch failure) then that end device will loose connection. There is nothing you can do about that. If the device is really important, be sure to make LAGs and connect to a stack if possible.
I hope that answered your question.
Cheers
JohnC_V
Aug 04, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- MotivITAug 05, 2017Aspirant
Hi,
My question is still unanswered. I know High Availability can be achieved but how exactly? For example, Switch 1 (48 port) has 40 devices connected to the ethernet ports. Then 35 devices connected to the ethernet ports of Switch 2 (48 port). 40 + 35 = 75 devices. Lets say Switch 1 went down. How will Switch 2 can serve all the connected devices to Switch 1? Or how it can serve all 75 devices where it only has 48 ports? What will happen in this case?
Thank You!
Arnel
- HopchenAug 05, 2017Prodigy
Hi,
Cheers- MotivITAug 07, 2017Aspirant
Exactly the answer I was looking for. Thanks for the brief and concise explanation, Hopchen!
