Boeffy
Nov 20, 2021Aspirant
How to assign PoE to the port of a XS728T
The XS728T has 8 ports PoE+ according to the technical data. (https://www.netgear.com/business/wired/switches/smart/xs728t/) Which ports are PoE (by default)? OR how to assign PoE to a port? ...
schumaku
Nov 20, 2021Guru - Experienced User
No idea from where this idea is coming from. On one hand it lacks the "P" in the product type, on the other hand don't mix it up with other models like some GS728xPx models where select or all ports offering PoE PSE.
OR
Neither - no kind of PoE, it's in no aspect a PoE switch with select PSE or any PD. The 28-Port and 48-Port 10-Gigabit Copper Smart Managed Pro Switch with 4 SFP+ Ports Software User Manual does mention PoE capabilities in the context of LLDP-MED discovery only.
Boeffy
Nov 21, 2021Aspirant
Hi Schumaku,
Thank for the reply. Good to know i can stop my search.
I am still confused though. Attached a printscreen of the technical data of the XS728T on the Netgear website
What does the following mean, if there is no PoE on the device?
- Number of PoE ports : 8
- PoE+ (802.3at) : 8
- Total PoE Power budget (Watts) : 8 PoE+ (55W)
- schumakuNov 21, 2021Guru - Experienced User
Reads like a markting mis-hap - some text of other netgear poe switch(es) seem to have hit this .... YeZ please review.
- DaneANov 21, 2021NETGEAR Employee Retired
Thank you for bringing this up. :) I have already reported this and this will be corrected.
The XS728T switch does NOT have any PoE/PoE+ ports and does NOT support PoE/PoE+. Kindly check the XS728T data sheet here.Regards,
DaneA
NETGEAR Community Team
- BoeffyNov 21, 2021Aspirant
All,
thx for helping and clarifying.
regards
Boeffy
