da7575's avatar
da7575
how to assign LAN port to VLAN ?
I setup 4 SSIDs corresponding to 4 VLANS  (admin/default,  Home, Work/IOT, and Guest).  I have a requirement to use a wired connection from a work computer being used at home.  So I want to assign the LAN port which is plugged into that work computer to the "Work/IOT" VLAN.     What are the steps to do this?
From what I can see the only way to force a specific computer to a specific VLAN/SSID is for the default admin VLAN 1 using "address reservation".   I dont have rights to manually change the IP on the work computer to be in the xxx.xxx.20.x range for the Work/IoT LAN But perhaps this isnt even the right approach anyway?
Can I assign a wired computer to any of these other VLANs other than than the defaiult vlan1?
  • schumaku's avatar
    schumaku
    Of course, you can. Consult the fine Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual starting from p.121 LAN settings ... ADVANCED > Setup > LAN Setup > LAN 1
    p.123 Change the employee LAN 2 settings
    ADVANCED > Setup > LAN Setup > LAN 2
    p.124. Change the IoT LAN 3 settings
    ADVANCED > Setup > LAN Setup > LAN 3
    p.125 Change the guest LAN 4 settings
    ADVANCED > Setup > LAN Setup > LAN 4.
