da7575
Dec 09, 2023Aspirant
how to assign LAN port to VLAN ?
I setup 4 SSIDs corresponding to 4 VLANS (admin/default, Home, Work/IOT, and Guest). I have a requirement to use a wired connection from a work computer being used at home. So I want to assign th...
- Dec 10, 2023
For anyone reading this with the same question, this question was actually answered on https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Can-Wired-LAN-connectivity-be-configured-on-VLANs-2-4-on-the/td-p/2348452 I just didnt see the resolution that got posted.
The UI experience for this threw me but makes sense now that its explained,
schumaku
Dec 10, 2023Guru - Experienced User
da7575 wrote:
I setup 4 SSIDs corresponding to 4 VLANS (admin/default, Home, Work/IOT, and Guest). I have a requirement to use a wired connection from a work computer being used at home. So I want to assign the LAN port which is plugged into that work computer to the "Work/IOT" VLAN. What are the steps to do this?
From what I can see the only way to force a specific computer to a specific VLAN/SSID is for the default admin VLAN 1 using "address reservation".
Can I assign a wired computer to any of these other VLANs other than than the defaiult vlan1?
Of course, you can. Consult the fine Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual starting from p.121 LAN settings ... ADVANCED > Setup > LAN Setup > LAN 1
p.123 Change the employee LAN 2 settings
ADVANCED > Setup > LAN Setup > LAN 2
p.124. Change the IoT LAN 3 settings
ADVANCED > Setup > LAN Setup > LAN 3
p.125 Change the guest LAN 4 settings
ADVANCED > Setup > LAN Setup > LAN 4.
