native_vlan
Aug 13, 2019Aspirant
vlan access port
I am trying to get to a device on a different vlan access port.
below is my current config (as saved from the Switch config saver download.)
!Current Configuration: ! !System Description "GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch, 6.3.1.19, B1.0.0.4" !System Software Version "6.3.1.19" !System Up Time "0 days 0 hrs 37 mins 32 secs" !Additional Packages QOS,IPv6 Management,Routing !Current SNTP Synchronized Time: SNTP Client Mode Is Disabled ! vlan database vlan 160-163 vlan name 160 "NATIVE" exit network mgmt_vlan 160 configure line console exit line telnet exit ! interface g2 vlan pvid 161 vlan participation auto 1 vlan participation include 161 exit interface g19 vlan pvid 160 vlan participation auto 1 vlan participation include 160 exit interface g23 vlan pvid 160 vlan participation auto 1 vlan participation include 160 exit exit
The device I am trying to get to is on G2. (VLAN 161)
My PC is on G19 (VLAN 160)
Upstream link is G23 (VLAN 160)
The upstream goes to a Cisco WS-C3750-48P
interface GigabitEthernet3/0/1 g23 description NETGEAR switch switchport trunk encapsulation dot1q switchport trunk native vlan 160 switchport trunk allowed vlan 160-163 switchport mode trunk end
The device on G2 is supposed have a default ip on it from the manufacturer, but I am not able to access it. I can see its MAC address in the ARP table, which is what the manufacturer said it would be.. :)
is there a way to sniff the traffic on the port G2? I can run wireshark on my PC, which is on Port 19.
Is there something else I need to do to get traffic from G2 (VLAN 161) to go out the Trunk (G23) to my router? the MAC address on the device on G2 is not appearing in my Cisco switch's ARP table or MAC Address Table. So I am not convinced the traffic on the switch (Port G2, VLAN 161) is leaving the switch to go upstream over the Trunk.
appreaciate any help.
Why routing if you want the VLANs on both switches?
On the port (or LAG) that is handling the trunk, configure all VLANs you want to pass the trunk as [T]agged - same config for VLAN (and in case LAG) on both switches.
- native_vlanAspirant
ok, so I played around and configured routing -> VLAN -> VLAN Routing
I am able to add routing for VLANs 161, 162, and 163. I am not able to add routing for VLAN 160. nor do I see how routing for
these other VLANs can go out of the switch. but it did create routing on the switch. In doing this, it things the next hop is the IP address I assigned the the VLAN interface. Why?
The manufacture's device on G2 was showing up with the correct IP Address with "Routing-> ARP"
Also, the adjacent Cisco switch was showing up in the Roiuting -> ARP table.
any examples on how to correctly configure "VLAN Routing Configuration" under Routing -> VLAN ?
Is there some equivalent way to configure "route redistribute connected" ?
when I configured the IP Address on the VLAN, the switch behaved as though that was the next hop.. ?
I keep gettting this error "The specified Static Router next hop router address cant the in the same subnet as the service network port"
But the service network (VLAN 160, 192.168.0.22) is not routing anything out... ?
no LAGs involved. how is this done in the gui? "configure all VLANs you want to pass the trunk as"
I have VLANs 160, 161, 162,163 I want all this traffic to pass through the trunk G23 to the Cisco Trunk, as defined above.
opps... your advice clued me in.. thanks!
removed all routing VLAN stuff.
then in Switching -> VLAN -> Port PVID Configuration :
G23 -> VLAN MEMBER becomes "160-163"
Then Switching -> VLAN -> VLAN Membership
go therough each desired VLAN ID and apply "T" to the trunk, G23, as well as verify "U" on the Access Port.
I can now ping my device. thanks again. I didnt realize how to make the group of VLANS be members in the web gui.
