native_vlan
Aug 13, 2019Aspirant
vlan access port
I am trying to get to a device on a different vlan access port. below is my current config (as saved from the Switch config saver download.) !Current Configuration:
!System Description "GS72...
- Aug 14, 2019
Why routing if you want the VLANs on both switches?
On the port (or LAG) that is handling the trunk, configure all VLANs you want to pass the trunk as [T]agged - same config for VLAN (and in case LAG) on both switches.
schumaku
Aug 14, 2019Guru - Experienced User
native_vlan
Aug 14, 2019Aspirant
no LAGs involved. how is this done in the gui? "configure all VLANs you want to pass the trunk as"
I have VLANs 160, 161, 162,163 I want all this traffic to pass through the trunk G23 to the Cisco Trunk, as defined above.
opps... your advice clued me in.. thanks!
removed all routing VLAN stuff.
then in Switching -> VLAN -> Port PVID Configuration :
G23 -> VLAN MEMBER becomes "160-163"
Then Switching -> VLAN -> VLAN Membership
go therough each desired VLAN ID and apply "T" to the trunk, G23, as well as verify "U" on the Access Port.
I can now ping my device. thanks again. I didnt realize how to make the group of VLANS be members in the web gui.
