otechcomputing
Dec 15, 2010Aspirant
Ports & VLANS
Hey all - severe brain issue today.
I have a core switch with one port set to tag traffic for vlans 10 & 20.
Into that core switch port, I have a GS748T, where I want the odd# ports to be vlan 20 & the even# ports for vlan 10.
Goal:
I have a DHCP server, serving both VLANS - so I was hoping that plugging into either row, would pull an IP from the DHCP server, but no luck.
I've been playing around with PVID & VLAN settings on the ports, but can't find the right combo. What's the setting for the uplink port on the 748?
Thoughts? Help?
Thanks!
-Tom
- Got it.
GS748:
DHCP release/renew no successful for different networks when I move the cable to the different VLAN ports.
So:
Interface/Port 1: VLAN 20.
VLAN 20 Membership: U
Port PVID config: VLAN 20
Uplink port: VLAN 20: T
Interface/Port 2: VLAN 10
VLAN 10 Membership: U
Port PVID config: VLAN 10
Uplink port: VLAN 10: T
- otechcomputingAspirantGot it.
GS748:
So:
Uplink port: VLAN 10: T - afurnessAspirantHi I have a similar issue in this thread, if you have time I'd really appreciate it if you could show and example of how it should be set up.
http://forum1.netgear.com/showthread.php?t=61614 - eeeevie24Aspiranthoping you can still reply on this topic, otechcomputing.
I have a similar situation where I have three VLANs (5/6/7) with 1 computer connected to each on ports 5/6/7 respectively. They shouldn't talk to each other. While I have an NTP server connected to port 8 which should talk to all VLANs.
According to your explanation, should I have set it up as:
VLAN 5:
Untag port 5
Tag Port 8
VLAN 6:
Untag port 6
Tag Port 8
VLAN 7:
Untag port 7
Tag Port 8
VLAN 1:
Untag port 8
Tag Port 5
Tag Port 6
Tag Port 7
Port 5 -> PVID 5
Port 6 -> PVID 6
Port 7 -> PVID 7
Port 8 -> PVID 1
Is this the proper configuration? Thank you in advance!!
______________________
[QUOTE=otechcomputing;308126]Got it.
GS748:
