da7575
Nov 29, 2023Aspirant
Can Wired LAN connectivity be configured on VLANs 2 - 4 on the Orbi Pro SXR30 AX1800
I assume the four ports on this model are all available for use on VLAN 1 "admin", but can any of them be configured instead to work on VLANs 2, 3, or 4 for what the Orbi labels as the "employee" , "IoT", or "Guest" vlans?
My use case is I want to connect my work pc which has a mandatory wired connection , at home on one of the VLANs other than VLAN1 which would be my trusted home PCs and phones. So effectively I'd have my home stuff on VLAN 1, my work wired PC on VLAN2, and then wireless IoT stuff on either VLAN 2,3, or 4 as well.
Sure, the switch ports are fully configurable.
Consult the fine Orbi Pro WiFi 6 Mini AX1800 Dual-band Mesh System (SXK30) User Manual (essentially the same content for all Orbi Pro systems), chapter "Change the VLAN profile for an Ethernet port " starting from p.85 ff. FMI.
1 Reply
