da7575
Nov 29, 2023Aspirant
Can Wired LAN connectivity be configured on VLANs 2 - 4 on the Orbi Pro SXR30 AX1800
I assume the four ports on this model are all available for use on VLAN 1 "admin", but can any of them be configured instead to work on VLANs 2, 3, or 4 for what the Orbi labels as the "employee" , "...
- Dec 01, 2023
Sure, the switch ports are fully configurable.
Consult the fine Orbi Pro WiFi 6 Mini AX1800 Dual-band Mesh System (SXK30) User Manual (essentially the same content for all Orbi Pro systems), chapter "Change the VLAN profile for an Ethernet port " starting from p.85 ff. FMI.
schumaku
Dec 01, 2023Guru - Experienced User
