Boeffy
Nov 20, 2021Aspirant
How to assign PoE to the port of a XS728T
The XS728T has 8 ports PoE+ according to the technical data. (https://www.netgear.com/business/wired/switches/smart/xs728t/) Which ports are PoE (by default)? OR how to assign PoE to a port? ...
Boeffy
Nov 21, 2021Aspirant
Hi Schumaku,
Thank for the reply. Good to know i can stop my search.
I am still confused though. Attached a printscreen of the technical data of the XS728T on the Netgear website
What does the following mean, if there is no PoE on the device?
- Number of PoE ports : 8
- PoE+ (802.3at) : 8
- Total PoE Power budget (Watts) : 8 PoE+ (55W)
schumaku
Nov 21, 2021Guru - Experienced User
Reads like a markting mis-hap - some text of other netgear poe switch(es) seem to have hit this .... YeZ please review.
- DaneANov 21, 2021NETGEAR Employee Retired
Thank you for bringing this up. :) I have already reported this and this will be corrected.
The XS728T switch does NOT have any PoE/PoE+ ports and does NOT support PoE/PoE+. Kindly check the XS728T data sheet here.Regards,
DaneA
NETGEAR Community Team
- BoeffyNov 21, 2021Aspirant
All,
thx for helping and clarifying.
regards
Boeffy
