MPS82
Nov 10, 2017Aspirant
How to block traffic between other ports but Internet access point using FS750T2
Hi, I'm new to network stuff and I hope someone could help me out with this problem: I have several apartments and one Internet access point (VPN gateway) connected to a 48 port switch. There...
- Nov 10, 2017
Hi MPS82
To separate devices, in that way that you want, you will need to use VLANs. It is the only proper way to do this. Each "department" in its own VLAN.
However, you will have a problem in that these VLANs need to be routed to the Internet as well. This switch cannot do that as it is only a layer 2 switch. It can do the VLAN part, but not the routing part. It is fine as long as your router/gateway can though. Is your router/gateway VLAN aware?
Cheers
Hopchen
Nov 10, 2017Prodigy
Hi MPS82
Cheers
- MPS82Nov 20, 2017Aspirant
Hi,
Thank you for comment! This was hepful. I will check if my gateway is VLAN aware from the supplier.
- HopchenNov 21, 2017Prodigy
No problem. Any questions - let us know :)
- hokie21Nov 21, 2017Tutor
This can be done with MAC ACLs. The switch will prevent traffic flow between the cusotmer ports, but allows all traffic to the Internet (router) port. You don't need to set up VLANs.
Make a MAC rule with ID=1, action permit, assign queue=0, redirect interface= the port connected to your router, match every=false. Souce and destination MAC and mask should be set to FF:FF:FF:FF:FF:FF.
Go into "MAC binding configuration" and set ACL ID to the name of the ACL you made above. Click the ports that are part of this special configuration.
Save it all and test. I checked it on my 724Tv2 just now and it works fine.
