BobGear
Nov 17, 2016Star
How to enable Jumbo Frames on GS116Ev2?
Hello, I have a new GS116Ev2. It came with the latest firmware installed (v2.0.1.26). I am trying to enable Jumbo Frames. I can not find the setting either in the Web interface or in the ProSafe ...
- Retired_MemberNov 20, 2016
Hi BobGear,
Welcome to Netgear Community!
For Jumbo Frame Size, we did doc in product data sheet (Jumbo Frame Support: Up to 9K packet size), it's enable by default and can't be modified. Also can't view it from Web GUI or Prosafe Utility tool. Btw, GS116Ev2 is a Web-Managed plus switch, didn't support to manage via telnet or SSH.
Let's know if you have further query, thanks.
ElaineP
Nov 17, 2016NETGEAR Expert
Hi BobGear,
Welcome to NETGEAR community!
on GS116Ev2,
Jumbo Frames (frame size is 9216), which is enabled by default on globally, and cannot be configured.
NETGEAR Employee
BobGear
Nov 18, 2016Star
Hi ElaineP, Thank you for the detail that the Maximum Frame Size is set to 9216. Very much appreciated. You may wish to document this somewhere. Thanks again, Bob
