2bsd
Sep 10, 2025Aspirant
How To Hard Reset a GS108Tv3 Switch
I have a GS108T v3 switch that doesn't configure itself at 192.168.0.239 when it's connected directly to a MacBook, nor do I see any DHCP requests coming from it. If I put it on a network with a DHCP...
schumaku
Sep 10, 2025Guru - Experienced User
Once a Netgear Smart Manages Switch is configured to a static aka. fixed IP address, it won't go through the DHCP process, requesting a LAN IP configuration from the DHCP server.
Only in case the DHCP does not succeed, it will fallback to the default LAN IP address 192.168.0.239 .
If you really need it factory resetted -> https://kb.netgear.com/24679/How-do-I-reset-a-smart-switch-to-factory-default-settings
