garaldejs
Dec 19, 2020Aspirant
How to link three GS728TP via sfp
Support, I am setting up three GS728TP and link together, i can only link 2 switches but if i connect the third switch, via SFP, the third switch is not able to connect to the two switches. I use...
- Dec 22, 2020
Hi Kurt,
Closed the issue, i figured out how to connect the switches using the sfp.
thank you for the hint anyway
michaelkenward
Dec 20, 2020Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
I will ask the Netgear moderator to move your message.
