garaldejs
Dec 19, 2020Aspirant
How to link three GS728TP via sfp
Support, I am setting up three GS728TP and link together, i can only link 2 switches but if i connect the third switch, via SFP, the third switch is not able to connect to the two switches. I use...
- Dec 22, 2020
Hi Kurt,
Closed the issue, i figured out how to connect the switches using the sfp.
thank you for the hint anyway
schumaku
Dec 21, 2020Guru - Experienced User
garaldejs wrote:I used LAG open the 4 sfp ports but still no communication
James,
This is either a much to short explanation of what you have configured - or if you configued one LAG spanning the four SFP+ ports and intend to use two and two connections it might be simply wrong.
-Kurt
garaldejs
Dec 21, 2020Aspirant
Hi Kurt,
Thank you for the reply, i am newbee in the netgear switches, can you help to suggest how can i link the three gs728tpv2 via sfp.
what are the steps that i have to follow to make it work.
thank you
