garaldejs's avatar
garaldejs
How to link three GS728TP via sfp
Support,   I am setting up three GS728TP and link together, i can only link 2 switches but if i connect the third switch, via SFP, the third switch is not able to connect to the two switches. I use...
  • garaldejs's avatar
    garaldejs
    Dec 22, 2020
    Hi Kurt,
    Closed the issue, i figured out how to connect the switches using the sfp.
    thank you for the hint anyway
ProSupport for Business
