cspell
Feb 12, 2020Tutor
How to save the running configuration in Netgear GS724T
Hello, I made some changes to this switch and now I want to save the running config to the startup config so I don't lose these changes on reboot. I can't seem to find how to do that on this swtich?...
- Feb 13, 2020What Michael shows is the ability to save the configuration, eg. as a backup.
On these Netgear switches, the config changes are applied to the running configuration and saved to the non-volatile storage automatically. This is different from some other major brands where the config is reflected in the running (volatile, memory) config only, and the admin must not forget to save the running config to the flash. Otherwise, all recent config changes would be lost.
schumaku
Feb 12, 2020Guru - Experienced User
...configuration as per the fine documentation by Web UI or the utility? There is no such thing un-experienced admins always forget about on the Smart Managed Plus and Smart Managed Pro switches.
