cspell
Feb 12, 2020Tutor
How to save the running configuration in Netgear GS724T
Hello, I made some changes to this switch and now I want to save the running config to the startup config so I don't lose these changes on reboot. I can't seem to find how to do that on this swtich?...
- Feb 13, 2020What Michael shows is the ability to save the configuration, eg. as a backup.
On these Netgear switches, the config changes are applied to the running configuration and saved to the non-volatile storage automatically. This is different from some other major brands where the config is reflected in the running (volatile, memory) config only, and the admin must not forget to save the running config to the flash. Otherwise, all recent config changes would be lost.
Coop59
Feb 13, 2020Aspirant
Hello I just thought I would chime in on this, There is a way for you to save the config. I am not sure about your model but mine has it under the maintenance -> Save Configuration.
I have attached a screenshot so you can see.
I hope this helps,
Michael
schumaku
Feb 13, 2020Guru - Experienced User
