fodderbot
Nov 17, 2021Aspirant
Hyper-V hosts single nic VLAN config
Hello I have 2 Hyper-V hosts with a single nic (Intel NUC's) and I would like the VMs on them to use different than default vlans. I configured the 2 ports as vlan 1 untagged (default) and vlan...
schumaku
Nov 17, 2021Guru - Experienced User
If you configure both Hyper-V hosts for using VLAN 5 on the adapter (while keeping VLAN 1 for the platform config), both VMs will connect to the VLAN 5.
The question is of/how you provide services like DHCP, Internet (default gateway, DNS relay), and how you handle the access to the VLAN 5 IP subnet which must be different of course fro the subnet on VLAN 1.
