fodderbot
Nov 17, 2021Aspirant
Hyper-V hosts single nic VLAN config
Hello I have 2 Hyper-V hosts with a single nic (Intel NUC's) and I would like the VMs on them to use different than default vlans. I configured the 2 ports as vlan 1 untagged (default) and vlan...
schumaku
Nov 17, 2021Guru - Experienced User
If you configure both Hyper-V hosts for using VLAN 5 on the adapter (while keeping VLAN 1 for the platform config), both VMs will connect to the VLAN 5.
The question is of/how you provide services like DHCP, Internet (default gateway, DNS relay), and how you handle the access to the VLAN 5 IP subnet which must be different of course fro the subnet on VLAN 1.
fodderbot
Nov 18, 2021Aspirant
Hi
thank you for your swift reply. I did not quite get what you mean however.
The Hyper-V hosts are connected on VLAN 1 while the adapter on the VMs is set to use VLAN 5.
I can see the mac addresses of the 2 VMs learned by the switch on VLAN 5, but I can't ping them from each VMs respectively, and firewalling is off...
Routing to other VLANS ot he internet should not be an issue as I would dedicate a VM with mulitple NIC's to do the routing.
I just can't understand why both VMs can't communicate on VLAN 5...
Many thx for your help!
- schumakuNov 18, 2021Guru - Experienced User
The VLAN5 is configued on the switch, and the ports are configured for VLAN1 untagged/PVID1 plus the VAN5 tagged membership, so building a trunk port?
- fodderbotNov 18, 2021Aspirant
Hello Schumaku,
exactly that's how it's configured right now...
Best regards,
Fodderbot
