rmcnally
Oct 28, 2021Follower
I have a netgear switch GS748Tv5 can not connect via web interface.
I have a Netgear switch GS748Tv5 connected via copper to a GS724 POE. The switch can be pinged and any PC connected can access the internet. However I can not connect to the GS748Tv5 via web interfac...
DaneA
Nov 07, 2021NETGEAR Employee Retired
Welcome to the community! :)
Is there a Management VLAN configured on your GS748Tv5? If yes, make sure that the PC you are using to access the web-GUI of the switch is directly connected to the port that belongs to the Management VLAN.
Is your GS748Tv5 being used as an unmanaged switch wherein everything is in default settings? If yes, I suggest you to perform a factory reset on your GS748Tv5 then try to access its web-GUI afterwards.
DaneA
NETGEAR Community Team
