blogthis
Apr 03, 2015Star
IEEE 802.3ad on GSS116E as advertised?
The new GSS116E switch (not old GS116E) is advertised as supporting IEEE 802.3ad link aggregation standards. Note that my Synology NAS does not support the proprietary Netgear-LAG mode, and requir...
- Nov 18, 2015
Hi Eaglehawk,
The GSS116E switch only supports static LAG (see datasheet) compared to the GS108T which is a smart managed switch which has static LAG and LACP support. See instructions on enabling LAG on the datasheet, please click here.
Thanks,
peak59
Oct 14, 2015Aspirant
I have the same problem :-( new switch and dosn't work LAG in combination with synology NAS. the old GS108T worked... Î'm disappointed.
JohnRo
Oct 23, 2015NETGEAR Employee Retired
Hello peak59,
Welcome to the community!
What is the model number of the switch do you have?
Thanks,
- EaglehawkNov 17, 2015Apprentice
I'm in the same boat as everyone above. I made the decision to purchase this particular switch because of the specifications, and then I came across this thread as I just started to build up my Synology. I have a GSS116E and a DS1815+.
I also pose the same question, will there be an update to fix this?
- JohnRoNov 18, 2015NETGEAR Employee Retired
Hi Eaglehawk,
Thanks,
