daveGPL
Jul 18, 2019Aspirant
IGMP Snooping JGS524Ev2
Hi, I bought 4 Netgear switches ( 3x JGS524Ev2 and 1x JGS524PE) and I am trying to setup IGMP to work properly. At the moment the settings look like this on all switches https://imgur.com/a/2e0Uz...
- Jul 22, 2019All switches require the same IGMP snooping config - otherwise thier ports will be flooded (as you have seen).
And yes, IGMP snooping can be enabled on one VLAN only - if there are multiple VLAN you have to define the VLAN.
Multicast groups are a different thing, and vase on the addresses (on the same VLAN).
daveGPL
Jul 22, 2019Aspirant
Hi,
2.6.0.24 - all of them.
I did reset to factory.
Only to multicast group, that means VLAN1 ?
I reconfigured only the main switch to use IGMP snooping and the rest of them in free run mode.
So the multicast is tagged now as VLAN1 on the main so everytime I pull a multicast from the main switch anywhere on the network, all the swtches go mad in blinking. I guess I need to add only the ports that should have access to mutlicast to the same VLAN 1 as the mcast, and the IP phones in a separate VLAN, WiFi in a separate VLAN, etc. right ? But I do struggle there since I do not know if the other switches should have the same IGMP setup as the main switch.
Cosmin
schumaku
Jul 22, 2019Guru - Experienced User
