daveGPL
Jul 18, 2019Aspirant
IGMP Snooping JGS524Ev2
Hi, I bought 4 Netgear switches ( 3x JGS524Ev2 and 1x JGS524PE) and I am trying to setup IGMP to work properly. At the moment the settings look like this on all switches https://imgur.com/a/2e0Uz...
- Jul 22, 2019All switches require the same IGMP snooping config - otherwise thier ports will be flooded (as you have seen).
And yes, IGMP snooping can be enabled on one VLAN only - if there are multiple VLAN you have to define the VLAN.
Multicast groups are a different thing, and vase on the addresses (on the same VLAN).
schumaku
Jul 22, 2019Guru - Experienced User
