XeroGreco360's avatar
XeroGreco360
Follower
Nov 12, 2019
In a switch GS108T-200NAS vs GS108T-300NAS
In a GS108T-200NAS switch, What is NAS? and what is the difference betwen 200 and 300 NAS?
  • StephenB's avatar
    Nov 15, 2019
    "NAS" is a code for the geography that the product is intended for - in this case it means North America.  The European model would end in EUS, Australian would be AUS, etc.  So it isn't related to the "NAS" in ReadyNAS - which means "network attached storage".
    The -200 and -300 section relates to the platform version. The 300 is newer (and runs different firmware).  In the specific case of the GS108T, there are three major versions (so far).  If you look at the support area, they are called v1, v2, and v3.  But in the part number, the three versions are -100, -200, and -300.   The three versions each need their own firmware.
    If you want to look at the specific differences:
ProSupport for Business
