holinbo1
Nov 10, 2024Aspirant
Insight App not seeing GS108Tv3 8-Port Gigabit Smart Managed Pro Switch
I have an Netgear Router (GS108Tv3 8-Port Gigabit Smart Managed Pro Switch) coming of an Eero Pro 6e. While I can manage the router through the webapp, the IOS Insight app is not seeing the router. I...
Nov 11, 2024Guru - Experienced User
The GS108T is a LAN switch, not a router.
What Apple device do you have?
What iOS version are you using?
Is FW on the switch up to date?
Be sure the Apple device and app is not being block at any point in the Network Map configuration.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
