BertAnsink
Oct 29, 2021Guide
Inter-VLAN routing MS510TXUP
Good day, I am using a Netgear MS510TXUP multi gigabit switch. (not the MX510TXPP as selected in model, but can't select the MS510TXUP) I am trying to use the VLAN routing functions, but with...
BertAnsink
Jan 25, 2022Guide
Hi DaneA ,
Sorry for the late response, I have been away from home for a while so only had time to dig into this again now.
The documents you posted post what I already did. I have set up the VLAN's and the routing table has the static routes, also the router.
I can not for the life of me get it to route between VLAN's, or acces the router/internet from any vlan except the one where the router sits on. I can ping the interface IP of the other VLAN, but then it stops there.
Is there any special setting I need for acces control?
I set the managment VLAN to another (99) but that is also of no help.
DaneA
Mar 15, 2022NETGEAR Employee Retired
I apologize for the late response. :catsad:
It would help if you post a diagram of your current network setup as well as the configuration you did and from there, the community members might be able to comment their suggestions and recommendations.
DaneA
NETGEAR Community Team
- Retired_MemberMar 16, 2022
Have you checked the firewall settings on the PCs? Traffic from other subnets than the one they are on may be blocked.
As for the Internet access, have you defined the necessary static route on the router for the other subnet? I guess your router is in the 196.168.1.0/24 subnet so the route should be 196.168.20.0/24, next hop 192.168.1.100. This is for replies from Internet.
- BertAnsinkMar 16, 2022Guide
DaneA and Retired_Member
The firewalls were switched off at both PC's.
Also the network is relatively flat, router (XR700) connected to one of the SFP+ ports and all clients to the other ports of the switch.
I think I might have solved the issue in the mean time though.
I tried it again but but with different VLAN's, VLAN60 and VLAN99. And that seems to work.
It seems that it simply does not want to route over the default VLAN (VLAN1) can this be the case?
Thanks for the help so far.
I own a MS510TX and a MS510TXPP. Setting inter-VLAN routing is very simple there. The only thing that needs to be done is to enable the 'Routing Mode' and define VLAN interfaces in 'VLAN Routing Configuration'. I do not use any wizards. I did not change the management VLAN. I have my Internet router in VLAN1, but I do not have any endpoint devices in there except for my management PC. All my endpoint devices are in the other three VLANs.
