BertAnsink
Oct 29, 2021Guide
Inter-VLAN routing MS510TXUP
Good day, I am using a Netgear MS510TXUP multi gigabit switch. (not the MX510TXPP as selected in model, but can't select the MS510TXUP) I am trying to use the VLAN routing functions, but with...
DaneA
Mar 15, 2022NETGEAR Employee Retired
I apologize for the late response. :catsad:
It would help if you post a diagram of your current network setup as well as the configuration you did and from there, the community members might be able to comment their suggestions and recommendations.
DaneA
NETGEAR Community Team
Retired_Member
Mar 16, 2022
Have you checked the firewall settings on the PCs? Traffic from other subnets than the one they are on may be blocked.
As for the Internet access, have you defined the necessary static route on the router for the other subnet? I guess your router is in the 196.168.1.0/24 subnet so the route should be 196.168.20.0/24, next hop 192.168.1.100. This is for replies from Internet.
- BertAnsinkMar 16, 2022Guide
DaneA and Retired_Member
The firewalls were switched off at both PC's.
Also the network is relatively flat, router (XR700) connected to one of the SFP+ ports and all clients to the other ports of the switch.
I think I might have solved the issue in the mean time though.
I tried it again but but with different VLAN's, VLAN60 and VLAN99. And that seems to work.
It seems that it simply does not want to route over the default VLAN (VLAN1) can this be the case?
Thanks for the help so far.
- Retired_MemberMar 16, 2022
I own a MS510TX and a MS510TXPP. Setting inter-VLAN routing is very simple there. The only thing that needs to be done is to enable the 'Routing Mode' and define VLAN interfaces in 'VLAN Routing Configuration'. I do not use any wizards. I did not change the management VLAN. I have my Internet router in VLAN1, but I do not have any endpoint devices in there except for my management PC. All my endpoint devices are in the other three VLANs.
Retired_Member
That's what I also thought but for me it didn't work when doing the same. The switch actually enables the static routes automatically when a device is detected on the specified VLAN so that should be in order.
I also set static routes in the router and wasn't able to ping that from other VLAN's other than 1. On VLAN1, I can ping the router when I set gateway 192.168.1.1 but not if I go via the VLAN interface, 192.168.1.100.
I don't know how different the firmware for a MS510TX/TXPP is compared to a MX510TXM/TXUP but afaik they should have pretty much identical features.
