Sam71
Jun 09, 2017Aspirant
Internet stops working when switches are connected using LAG - JGS524PE & JGS516PE
Hi all, Having an issue where the internet stops working when we connect a JGS524PE & JGS516PE via a 2 port LAG. The JGS524PE is the main switch in a detatched office and the JGS516PE runs a ...
- Jun 10, 2017
XavierLL wrote:Just a couple of things that hope helps you when you are onsite:
Configure first the switches without any of the LAG cables connected, and once you have configured both plug in the cables
Will Do!
If after configuring it you still have issues please change the cable and the port as a physical issue could also cause that the LAG is down
As far as I can remember each port works normally when the other is disconnected! Issue is the second switch is in a pain of a spot to get to (in the roof space in a small data cabinet) so the whole process of pysically patching cable is a slow process.
Sam71
Thanks for your reply Xavier,
The only thing I did notice is that Admin mode would not stay active after I selected it!
i.e. it would be back to Disabled once I went back in.
I am quite sure that the LAG ports are the ones connected on each switch, I am going back to site on Monday!
I am thinking unless I can get the admin mode to enable I am going to be going in circles like the data traffic! :smileyhappy:
XavierLL
Jun 09, 2017NETGEAR Employee Retired
You are welcome Sam71!
- Configure first the switches without any of the LAG cables connected, and once you have configured both plug in the cables
- If after configuring it you still have issues please change the cable and the port as a physical issue could also cause that the LAG is down
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
- Sam71Jun 10, 2017Aspirant
Will Do!
- Sam71Jun 11, 2017Aspirant
I went on site today and it is now working!
Qos was setup on one of the switches so I thing that was causing the grief.....
- Sam71Jun 12, 2017Aspirant
Looks like I spoke to soon!
Aparently the internet (netflix etc.) is now not working in the house. It is fine in the office which is now connected via LAG.
The cameras are also working fine! It is like the traffic is only going one way over the LAG.
I am just thinking it may be better to create a Vlan on the second switch (in the house) and connect this directly to a lan port on the modem router, and give up on the LAG connection. This would separate the cameras away from the network in the house.
