hacesoft
Dec 08, 2019Tutor
IP Alias?
Have a nice day, i have a question about mirroring web switch configuration: Switch has static address set for login to administration: 192.168.40.1 In switch I have 4x VLAN. If I have the VLAN a...
- Dec 09, 2019
Hi hacesoft,
I'm sorry for not being clear about access control.
In the access control you can just only set permit ip address on Gui, then only perimt ip address can access switchs,
For example:
permit 192.168.20.20 ---- then no other addresses are accessible except this one
the access control was deny any by default. it seems like acl deny any by default.
Please try it.
thank you
kevin_hong
Dec 09, 2019Apprentice
Hi hacesoft,
Welcome to community,
Yes, the behavior was normal, you can set access contraol on switch , then only the specifled ip address can access the switch.
https://kb.netgear.com/24715/How-do-I-configure-management-access-control-on-a-smart-switch
PS: you can learn what is access control first
https://kb.netgear.com/24712/What-is-management-access-control-on-a-smart-switch
- hacesoftDec 09, 2019Tutor
Good evening,
thank you for answer.
I tried it according to the instructions. I probably set everything up well and yet it doesn't work. The switch is accessible as before. I want it to be accessible from VLAN20, even from the specific address of 192.168.20.20, and from VLAN40 from 168.168.40.20.
On the enclosed image I am sending as I did not configure the switch.
- kevin_hongDec 09, 2019Apprentice
Hi hacesoft,
For example:
Please try it.
thank you
- hacesoftDec 10, 2019Tutor
Good evening,
I tried it according to your recommendation, set only the IP address of the PC that the switch will set up and it also does not work.
Everyone has access to the switch. I restarted the switch even after setup, what if it would help, but no result.
Perhaps it is a question directly to someone from NETGEAR, why it does not work.
