Faye_10
Jan 02, 2022Aspirant
IP Conflict
Hi support team, We have a GS752TPv2 switch and the previous person installed the switch on our network did not know the IP address pickup by the switch conflict with our DNS Server Ip address. ...
schumaku
Jan 02, 2022Guru - Experienced User
If the switch management interface is configured by DHCP, you need to change the DHCP config, resp. the assignment between the switch admin MAC address and the IP address assigned. On one hand, define a different IP address there (in the IP pool range typically), on the other hand the DNS server IP should be excluded from the DHCP range or reserved by putting in a "random" (or the real DNS server adapter) MAC address so it's reserved either way.
Faye_10
