Mikeemikew
Aug 10, 2023Tutor
IPv4 Management VLAN Configuration
Any assistance would be appreciated. IPv4 Management VLAN Configuration Parameters Management VLAN Identifier: 99 Routing Mode: Enabled Configuration Method: Manual IP Address: 192.168.99.5 Su...
schumaku
Aug 10, 2023Guru - Experienced User
You have enabled the routing, so out of the box there are no ACLs prohibiting the inter-VLAN access. Needles to say, this is different on switches without routing capabilities.
