tbrown13's avatar
tbrown13
Is it possible to enable telnet or ssh on a MS510TX ?
I just purchased a MS510TX with the intent of using either telnet or ssh (preferably ssh) to configure it. I've done this with Prosafe switches and thought the MS510TX would be perfect for this but sadly I cannot find a way to enable telnet or ssh. Any help appreciated.
thanks
trent
  • The shell access isn't intendend for production CLI access, and in no aspect supported.
    As usual, you can enable "Remote Diagnostics" via "Maintenance>Troubleshooting>Remote DIagnostics"
    Then telnet the manage ip address via port 60000
    Works on the MS510TXUP for example, too
  • schumaku's avatar
    schumaku
ProSupport for Business
