AeonJJ
Mar 13, 2024Aspirant
JGS516PE - Which VLAN does the switch management interface sit on? Switch DHCP client & management?
This is a 16 port switch. I want two port based VLANs; production traffic and management of the switch. I have "Production" as VLAN 2 and uses ports 1-15 I have "Management" as VLAN 1 and uses ...
schumaku
Mar 13, 2024Guru - Experienced User
Everywhere, because there is no managed core with a VLAN-aware controller. A tiny uC (8051 class) does implement the Netgear Switch Discovery Protocol (NSDP), and a very restricted TFTP, and a simple Web UI. Any non-tagged traffic flowing through the switch is considered, so the DHCP address assigned could end on any VLAN.
- AeonJJMar 13, 2024Aspirant
That's kind of crazy, isn't it. Wouldn't it have to select a single port to issue the request? Default to Port 1? It can't be sending out a DHCP request on all ports.
- schumakuMar 13, 2024Guru - Experienced User
Ports are irrelevant in this design, in fact on almost all Plus switches. Technically, al these are unmanaged switches, with some configuration level features. Few exceptions, are built on managed cores.
The same applies to the IGMP Multicast implementation: The uC does "listen" to all traffic flowing through the switch.
